Linux: File replication
Posted: Fri Feb 11, 2005 12:47 pm
In order to synchronize the files on 2 machines, I've written a few shell-scripts to do the job.
(to avoid reader-confusions: This should be a ONE way replication of WHOLE files. It will NOT detect bytewise changes and it will NOT merge changes from both sides.)
The idea behind it is:
1) create a filelist from Point A
2) create a filelist from Point B
3) Use "diff" to find the changes
- a) deleted
b) modified
c) added
4) Update the files on Point B. (del/mod/add)
...I've thought about using checksum-lists, but I found out that it was sufficient using the plain directory listing which saves a lot of processing time.
This replication is running in an environment where so many files are in ONE folder that ls-ing the contents gives a "bash: /bin/ls: Argument list too long", so you can imagine HOW many files there are...
Of course, going for checksums would be the most reliable way.
detect changes using diff, grep and awk
Posted: Fri Feb 11, 2005 12:52 pm
The really tricky part is to differ between
deleted, modified and added files by using the checksum lists.
The tools I've used were "diff", "grep" and "awk":
CUR_LIST=$DIR_LIST; #manually skipped usage of MD5 sums
if test -z $FIRST_TIME; then
tmp_main=$CUR_LIST.$DIFF_SUFFIX;
#find changes in file structure:
$DIFF $CUR_LIST.old $CUR_LIST > $tmp_main
tmp_old=$CUR_LIST.old.$DIFF_SUFFIX;
tmp_new=$CUR_LIST.new.$DIFF_SUFFIX;
tmp_diff=$CUR_LIST.temp.$DIFF_SUFFIX;
cat $tmp_main | grep "<" | awk -F" " '{print $10}' > $tmp_old
cat $tmp_main | grep ">" | awk -F" " '{print $10}' > $tmp_new
#find files which do NOT appear in both listings (=added, deleted):
$DIFF $tmp_old $tmp_new > $tmp_diff
#create temp filenames:
tmp_del=$tmp_main"."$DEL_DIFF_PRE;
tmp_add=$tmp_main"."$ADD_DIFF_PRE;
tmp_mod=$tmp_main"."$MOD_DIFF_PRE;
cat $tmp_diff | grep "<" | awk -F" " '{print $2}' > $tmp_del
cat $tmp_diff | grep ">" | awk -F" " '{print $2}' > $tmp_add
#find files which appear in the old listing, but haven't been deleted (=modified):
$DIFF $tmp_old $tmp_del > $tmp_diff
cat $tmp_diff | grep "<" | awk -F" " '{print $2}' > $tmp_mod
#add modifications of all buckets to ONE difference listing:
cat $tmp_add >> $CUR_DIFF_LIST.$ADD_DIFF_PRE
cat $tmp_mod >> $CUR_DIFF_LIST.$MOD_DIFF_PRE
cat $tmp_del >> $CUR_DIFF_LIST.$DEL_DIFF_PRE
cat $tmp_main >> $CUR_DIFF_LIST.all
else
echo -n " Cannot compare since this is the first run.";
fi
replication environment: LAN or WAN?
Posted: Fri Feb 11, 2005 1:36 pm
How to get the files?
In some environments, shell-access cannot be provided (e.g. website provider), thus I've thought it might be useful to implement the whole thing as a .php program.
The "main" site (A) would then be quite passive, by just delivering the dirlists "on demand" (over php).
For security reasons there should be some kind of "token" in to-be-replicated folders, so that the php-script knows if it is allowed to hand out a listing at all.
The B-site could then calculate the changes and "request" a link-list from the php-script by uploading the "delta-list". The linklist could be downloaded from A to B by using wget's recursive functionality.
There should also be some sort of cheap authentication mechanism.
If scp works, it would also be possible to let the client download the files over ssh. But it is very unlikely that this is possible with default website providers and thus this should only be considered if both computers are under your control.
For automated scp's you would have to use key-based logins (ssh2), which would enable an intruder on the B-site to logon to A-site without a password!. Very dangerous!
Of course, if you're thinking about a LAN where the 2 replication sites are only available internally and you do not want to set up a webserver, the scp-variant would be a useful alternative.
Öh
Posted: Fri Feb 11, 2005 1:52 pm
by gilthanaz
someone's already written it.
Posted: Sat Feb 12, 2005 7:11 pm
hm...
I somehow had the feeling that there MUST be some replication functionality available under Linux, but at the time when I first wrote those simple scripts, I haven't found any useful tool...
Seems that I've overlooked one:
http://rsync.samba.org/rsync/features.html
...but since it is doing a really sophisticated replication (only transmitting changes within files, ...) it uses a lot of
memory, depending on the number of files to process.
hm... would the few advantages of my version (small, simple, php) really justify its implementation?
(edit): I don't think so (
)... I've just checked rsync's parameters and it looks like it can be "simplified" (e.g. "--whole-file")
More file synchronisation
Posted: Wed Jul 20, 2005 2:09 pm
Gilthanaz has found some quite promising file replication/synchronisation tool:
http://www.cis.upenn.edu/~bcpierce/unison/
the important feature we were looking for is that it can run on Linux
AND windows.
