Excerpts of these videos are availabe there as SGI image sequences (SVT Multiformat).
I will describe here how to convert these SGI image sequences to video files, with different output colorspaces (pix_fmt), using FFmpeg.
The command base we'll be using looks like this:
ffmpeg -f image2 -start_number $START_NUMBER -i %05d.sgi -an -f $FORMAT -vcodec $VCODEC -g 1 -pix_fmt $PIX_FMT $OUTPUT_VIDEOThe variables used here are as follows:
- $START_NUMBER: The first frame number used in the image sequence
(Example: "CrowdRun" has the first frame "03556.sgi" so it starts with "3556". "ParkJoy" is 7762, "DucksTakeOff" is 6494, and so on...) - $FORMAT: The output video format (e.g. "avi", "nut", "yuv4mpegpipe")
- $VCODEC: The output video codec (e.g. "rawvideo", "ffv1")
- $PIX_FMT: The output pixel format. This is also used to define colorspace and subsampling fo the output video.
- $OUTPUT_VIDEO: The filename of the resulting video.
If you want to convert the RGB SGI images to YUV with 8 bits-per-component, you can use a "yuv4mpegpipe" as output format. The following command would create an uncompressed YUV 422 planar (yuv422p) in an mpeg container:
ffmpeg -f image2 -start_number 3556 -i 1_CrowdRun_576i25_CgrLevels_SINC_FILTER_SVTdec05_/%05d.sgi -an -f yuv4mpegpipe -vcodec rawvideo -g 1 -pix_fmt yuv422p CrowdRun_576i25-yuv422p.y4mAs I haven't found a container/format combination to store uncompressed RGB in an interoperable and commonly supported way, I've used "nut" as container for the time being (although it still has issues with >8 bits-per-component):
ffmpeg -f image2 -start_number 3556 -i 1_CrowdRun_576i25_CgrLevels_SINC_FILTER_SVTdec05_/%05d.sgi -an -f nut -vcodec rawvideo -g 1 -pix_fmt rgb24 CrowdRun_576i25-yuv422p.nutThe framemd5 checksums of the transcoded sources, including the generated output videos can be found online for the 576i25 and the 720p50 variants.
