Vimperator: hide navigation bar in newer Firefox
Since some versions, vimperator is not able to hide its navigation toolbar in newer Firefox versions.
It has to be hidden manually every time Firefox is restarted:
:set gui=nonavigation
Here's a workaround for how to hide it again permanently, just like it used to work in the past:
1) Create a "vimperatorrc" config file:
(by default, there's none)
Enter the following command in vimperator's commandline in the browser:
: mkvimperatorrc
Then, exit Firefox.
2) Edit your vimperatorrc:
On GNU/Linux, it's in your home folder, on Windows, it's in "C:\Users\$USERNAME\".
Add the following line at the bottom:
set "gui=nonavigation"
That's it.
