BWF Peak Enveloper Chunk with FFmpeg
Since 2013, FFmpeg can create the "Peak Envelope Chunk" (levl) in Broadcast Wave Files (BWF).
To see if and which options your FFmpeg version supports, use the following command:
$ ffmpeg --help muxer=wav full
The NOA Audio Solutions archiving systems uses this envelope chunk without payload as standalone "Peakfiles" (.lpk).
They can be created as follows:
$ ffmpeg -i audiofile.wav -f wav -write_peak only audiofile.wav.lpk
In order to create such a peakfile for a video, use the following command:
$ ffmpeg -i videofile.avi -vn -f wav -write_peak only videofile.avi.lpk
