What few know is, that QCTools' analysis algorithms are all implemented directly in FFmpeg's libraries. Therefore, the "FFprobe" commandline tool can be used to generate a QCTools-compatible XML. That XML contains all the video signal measurements which are rendered in QCTools' analysis graphs in the user interface.
*) Syntax described in QCTools's help:
The actual syntax for using ffprobe for generating these XMLs is already described in QCTools' help:
Help > Data Format
1) For a file with video AND audio named EXAMPLE.mov:
ffprobe -f lavfi -i "movie=EXAMPLE.mov:s=v+a[in0][in1],[in0]signalstats=stat=tout+vrep+brng,cropdetect=reset=1,split[a][b];[a]field=top[a1];[b]field=bottom[b1],[a1][b1]psnr[out0];[in1]ebur128=metadata=1[out1]" -show_frames -show_versions -of xml=x=1:q=1 -noprivate | gzip > EXAMPLE.mov.qctools.xml.gz
ffprobe -f lavfi -i "movie=EXAMPLE.mov,signalstats=stat=tout+vrep+brng,cropdetect=reset=1,split[a][b];[a]field=top[a1];[b]field=bottom[b1],[a1][b1]psnr" -show_frames -show_versions -of xml=x=1:q=1 -noprivate | gzip > EXAMPLE.mov.qctools.xml.gz
If you store the resulting .qctools.xml.gz file right next to the video with the same name, it will be opened automatically when you load the video in QCTools.
Example:
Videofile: video.mkv
QCTools sidecar XML: video.mkv.qctools.xml.gz
Have fun!
