In order to find out if your harddisk has 4k (4096 Bytes) blocks or 512 Bytes, use the command "hdparm" (In my setup, the 3TB disk is /dev/sdd. You must change that to fit yours):
$ sudo hdparm -I /dev/sdd
(I only copy/pasted the beginning of the output here, as it contains the important information about cylinders, sector size, etc)
Model Number: WDC WD30EFRX-68AX9N0
Serial Number: WD-WMC1T1244880
Firmware Revision: 80.00A80
Transport: Serial, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
Standards:
Supported: 9 8 7 6 5
Likely used: 9
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 268435455
LBA48 user addressable sectors: 5860533168
Logical Sector size: 512 bytes
Physical Sector size: 4096 bytes
Logical Sector-0 offset: 0 bytes
device size with M = 1024*1024: 2861588 MBytes
device size with M = 1000*1000: 3000592 MBytes (3000 GB)
cache/buffer size = unknown
CAUTION: If you use "fdisk" on >2TB disks with GPT, they will claim that the disk has 512/512, as well tell you that the partition starts at sector #1. This is not true!
fdisk doesn't read GPT correctly and therefore the information displayed is inaccurate.
For example, running "fdisk -l /dev/sdd" returns the following:
WARNING: GPT (GUID Partition Table) detected on '/dev/sdd'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdd: 3000.6 GB, 3000592982016 bytes
255 heads, 63 sectors/track, 364801 cylinders, total 5860533168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sdd1 1 4294967295 2147483647+ ee GPT
sudo sgdisk -p /dev/sdd
Disk /dev/sdd: 5860533168 sectors, 2.7 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): D6A65FFD-D1B0-4FEA-BE3A-2DB964B82C29
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 5860533134
Partitions will be aligned on 2048-sector boundaries
Total free space is 5860533101 sectors (2.7 TiB)
Number Start (sector) End (sector) Size Code Name
sudo sgdisk -a 2048 -n 1:2048:5860532224 -t 1:8300 -c 1:"My stuff" /dev/sdd
- "-a 2048" tell sgdisk to align the sectors in a multiple of 2048
- "-n 1
5860532224" creates a partition number 1, from sector 2048 to 5860532224
- "-t 1:8300": Partition type will be "Linux filesystem"
- "-c 1:"My stuff"" is just a human readable name you can give the partition.
Let's see how to get the values for this command:
- The end sector is calculated, by taking the last usable sector (from "sgdisk -p" output), which is "5860533134", then divide this by 4096 (=your sector size) and multiply the result (without decimal places) again with 4096 and subtract "1". As formular it might look like: (int(last_usable_sector/4096) * 4096) -1
The result is: "5860532223" - The partition types can be listed with "sgdisk -L". There you have a line saying: "8300 Linux filesystem"
The output should look like this:
Total free space is 2925 sectors (1.4 MiB)
1 2048 5860532223 2.7 TiB 8300 My stuff
sudo mkfs.ext4 -m 0 -b 4096 /dev/sdd1
- "-b 4096" sets a blocksize of 4096
- "-m 0" is used to reserve 0% for root. The default value would be 5%.
To reserve space for root is a great feature for system partitions, but not for storage. Since this disk is intended for pure user-storage, 5% would be 135 GiB unusable by anyone else but root.
