HowTo: Quick-n-dirty extraction of date inside WAV
peter_b
Chatterbox
Post by peter_b »
This HowTo describes how to extract the date/time information from inside a WAVE file (.wav), in case the file timestamp was lost.
NOTE: This only works, if the recording device or application wrote the date as metadata inside the WAVE file. This must not always be the case.
This approach uses only common tools, usually available out-of-the-box on any unixoid operating system (GNU/Linux, MacOS, etc).
Here's a one-liner:
$ head -c 10000 *.wav | cat -v | grep -E "20[0-9][0-9]"
NOTE: The Regular Expression "20[0-9][0-9]" only covers dates between 2000 and 2099. Adjust this accordingly.
The output may be a bit rough, since "grep" is intended for text, but now it dumps also binary data from the WAVE header:
WAVEfmt ^P^@^@^@^A^@^B^@DM-,^@^@^PM-1^B^@^D^@^P^@LIST.^@^@^@INFOICRD^K^@^@^@2016.05.12^@^@ISFT^N^@^@^@Lavf57.36.100^@data^PM-^U_
Yet, you can see the date/time string (in YYYY.MM.DD notation):
2016.05.12
If you want to loop over several files, and list filename + "data block with date", you can
$ for FILE in *.wav; do echo "File: $FILE"; head -c 10000 $FILE | cat -v | grep -E "201[0-9]"; echo ""; done >> date.txt
This writes the results to "date.txt".
I've used this to retrieve the date of audio recordings on deleted files, extracted using "Scalpel" - so their file timestamp was lost.
peter_b
Chatterbox
Re: HowTo: Quick-n-dirty extraction of date inside WAV
Post by peter_b »
Another approach, with results easier to parse for further automation is, to use FFmpeg's "ffprobe" tool:
$ ffprobe -v error -i $WAVE_FILE -show_format | grep -i "date"
The result per file looks like this:
TAG:date=2015.12.09
