HowTo do a quick deep hashing/fixity of subfolders
You may find or search this under "md5deep", but the command - as well as its package - was renamed/superseeded by "hashdeep".
Where "md5sum" creates a textfile per folder, the command "hashdeep" can be used to create fixity information for a whole subfolder structure.
The basic command is simple:
$ hashdeep -l -r -c md5 .
Parameters:
  • -l: Relative file paths: Makes the file more "portable" (easier to check even when moved to completely different location)
  • -r: recursive. Include subfolders.
  • -c md5: compute MD5 hashcodes.
I chose to do MD5 only, because I it's sufficient for data integrity checks, and I'm not using it for security.
Since hashdeep's default is MD5+SHA256, I dropped SHA256 to save computing power and speed up the process :D
The output looks something like this:
%%%% HASHDEEP-1.0
%%%% size,md5,filename
## Invoked from: /media/pb/CAM_SD
## $ hashdeep -l -r -c md5 .
1328742227,62c8a3a5d58316d0758413bc414406ad,./DCIM/101XDPHH/S1010001.MP4
1327486509,34eec99491abe839db31c130320a2e04,./DCIM/101XDPHH/S1010002.MP4
1327514894,11d0e549e9832bbe8970e81e1bcdc494,./DCIM/101XDPHH/S1010003.MP4
1327837525,7f1c5e06a3c1fa7a179473c780fb6a7d,./DCIM/101XDPHH/S1010004.MP4
1328092473,d2f9bf6d35e4f763adb76edc608f8c92,./DCIM/101XDPHH/S1010005.MP4
260114642,3edd2bd0908e0accb66e2af72f00116e,./DCIM/102XDPHH/S1020004.MP4
1328250451,13e610710e2f9d323f4dd2c25620a540,./DCIM/101XDPHH/S1010006.MP4
613737399,677d7c2c6b21ad11969fdd8a840a938b,./DCIM/102XDPHH/S1020002.MP4
1327236635,e53122187f81e5da11b9643fad3e8b1f,./DCIM/101XDPHH/S1010007.MP4
1322809572,1652fb231da8c7a7daca0816e84cdef9,./DCIM/102XDPHH/S1020001.MP4
1328600259,59d28e4dfbc6972536f594031012e2ca,./DCIM/102XDPHH/S1020003.MP4
https://linhost.info/2010/05/using-hash ... integrity/
EDIT (May 17th, 2019):
Changed to relative paths (added "-l"), because I think it's the more regular use case that the files will be moved sooner or later.
Makes validation easier and less confusing.
Validating with existing hashdeep textfile
Here's one way to check the current folder, with the data in the fixity textfile "MD5DEEP.md5":
$ hashdeep -l -e -vvv -r -a -k MD5DEEP.md5 .
Parameters:
  • -l: Relative paths mode. Otherwise you'll only get "file moved" messages ;)
  • -e: Estimate time. Shows a progress indicator. Must-have for video handling.
  • -vvv: Tell us what you're doing. With less verbosity, you'll only see errors - and therefore "dark screen" while its computing. Better with "vvv" :)
  • -a: Audit mode = compare and verify/validate.
  • -k MD5DEEP.md5: The textfile that contains fixity data from hashdeep (MD5, etc). I've arbitrarily named it ""MD5DEEP.md5".
