Debian: Disable IPv6
For internal network computers, I disable IPv6 in most cases.
This here is basically just a copy of the "How to turn off IPv6" section on the Debian Wiki:
1) Edit /etc/sysctl.conf
and add the following parameters to kernel:
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
Note: This disables IPv6 on all network interfaces.
Optional: If you want to only disable it on specific ones, you can use a syntax like this:
net.ipv6.conf.eth0.disable_ipv6 = 1
(This would apply only to "eth0" for example)
2) Apply changes:
After editing sysctl.conf, you should run sysctl -p to activate changes or reboot system.
That's it.
IPv6: use "/etc/sysctl.d"
Another option that I now find slightly cleaner than modifying "/etc/sysctl.conf" directly, is to use the "/etc/sysctl.d" folder to keep this config separately (and easier to enable/disable it).
1) Create a file called "/etc/sysctl.d/70-disable-ipv6.conf"
2) Put the same lines in that file as you would into sysctl.conf directly
3) Save it and either reboot or reload sysctl:
$ sysctl -p -f /etc/sysctl.d/70-disable-ipv6.conf
Feels cleaner :D
