Linux: Rebirth 338 & wine
Posted: Fri Jun 20, 2008 1:28 pm
Rebirth is an old music application (drum sequencer, synthesizer sound, ...) which has been released freely on http://www.rebirthmuseum.com.
(Unfortunately, it's not real Free Software - I mean: GPL)
I'm still kind of stuck to this program, so I wanted to try using it with Wine (v0.9.59). Here's howto get it working on Kubuntu Hardy:
1) Download the CD-ROM .iso image from www.rebirthmuseum.com
2) Unzip it, so that you have the .iso file.
3) Create a mount point for that image file:
4) Mount the image:
If you want it to be persistent (or at least more conveniently mountable), enter it in /etc/fstab by adding this line:
Then you can simply do a "mount /mnt/rebirth" - even as non-root user.
5) Install ReBirth, by starting "Install ReBirth RB-338.EXE".
Known problem: Due to security reasons, memory handling for 16-bit support was changed in recent Ubuntu updates, so you might run into this error:
6) Configure Wine to mark /mnt/rebirth as CD-drive.
(Either start "winecfg" from the commandline, or open the application menu and select "Wine > Configure Wine")
- There, select "Drives" and add "/mnt/rebirth" as e.g. "D:"
- Click on "Show Avanced"
- Select Type: "CD-ROM"
- Manually assign: "Label": RB338V20
And confirm with "OK".
That's it. You should now be able to run the official and free ReBirth version in Wine.
The link to winehq's application database for ReBirth might help with future problems.
sudo mkdir -p /mnt/rebirthCode: Select all
sudo mount -o loop -t iso9660 /path/to/rebirth/image/rebirth.iso /mnt/rebirthCode: Select all
/path/to/rebirth/image/rebirth.iso /mnt/rebirth iso9660 loop,user,noauto5) Install ReBirth, by starting "Install ReBirth RB-338.EXE".
You can workaround this problem by changing sysctl parameters first:winevdm: unable to exec '--app-name': 16-bit support missing
sudo sysctl -w vm.mmap_min_addr=0(Either start "winecfg" from the commandline, or open the application menu and select "Wine > Configure Wine")
