Convert VirtualDub joblist script to XML - using PHP
Posted: Fri Jun 25, 2010 2:51 pm
I had to parse VirtualDubs joblist (Sylia script) to extract some metadata like input video filename, frame-range, etc.
My idea was to use regular expressions to transform the linear script into an XML structure, for more convenient parsing.
Here's my conversion function:
* Converts a VirtualDub joblist file (Sylia Script) into an XML-like structure
* and returns a "SimpleXML" object, containing the data.
* More information about syntax and content of a VirtualDub.jobs file at:
*          http://www.virtualdub.org/docs/vdscript.txt
function convert_virtualdub_joblist_to_xml($filename)
$joblist = file_get_contents($filename);
if ($joblist == false)
	printf("ERROR: Cannot read file: '%s'\n", $filename);
	return false;
$pattern = array(
			'/\/\/--*/',                            // Remove comment lines consisting only of hyphens
			'/\/\/ \$job "(.*)"/',                  // Begin job XML node
			'/\/\/ \$endjob/',                      // End job XML node
			'/\/\/ \$(\w*) "?(.*?)"?\r/',           // Transform comment data into nodes (e.g. "$start_time")
			'/VirtualDub\.Open\(.*\);/',            // Open settings XML node
			'/VirtualDub\.Close\(\);/',             // Close settings XML node
			'/VirtualDub\./',                       // Indent sub-nodes
			'/VirtualDub\.(\w*)\.(.*)\((.*?)\);/',  // Transform sub-object function calls to nodes
			'/VirtualDub\.(\w*)(.*);/',             // Transform function calls to nodes
			'/-- (.*?) --/',                        // Double hyphen (--) breaks XML comments. Get rid of it
			'/\/\/(.*?)\r/',                        // Transform all other comment strings "//" to XML comments
$replacement = array(
			'<job name="\1">',
			'</job>',
			'<\1>\2</\1>',
			'<settings>',
			'</settings>',
			'    VirtualDub.',
			'<\1 action="\2">\3</\1>',
			'<\1>\2</\1>',
			' \1 ',
			'<!--\1 -->',
// The xml root name is hardcoded to "virtualdub_joblist" - because it's not used anywhere else:
$xml_string = sprintf("<virtualdub_joblist>\n%s\n</virtualdub_joblist>\n", preg_replace($pattern, $replacement, $joblist));
$simple_xml = simplexml_load_string($xml_string);           // Has the nice side-effect of tidying up the XML
return $simple_xml;
