Setting up Debian Wheezy as kvm host
Posted: Fri Aug 09, 2013 8:01 pm
WARNING: This HowTo is still work in progress. Do not use it, yet. Sorry
This HowTo is based on Falko Timme's tutorial for "Virtualization With KVM On A Debian Squeeze Server ".
1) Install the required packages for KVM virtualization:
2) Add your user to the groups "kvm" and "libvirt":
NOTE: This applies to the user you're currently logged in with.
3) Create a network bridge:
TODO: network configuration
4) Create a virtual machine for the Debian client:
Parameters are:
$ apt-get install screen kvm qemu-kvm libvirt-bin virtinstCode: Select all
adduser `id -un` libvirt
adduser `id -un` kvm3) Create a network bridge:
$ apt-get install bridge-utils4) Create a virtual machine for the Debian client:
$ virt-install --connect qemu:///system \
--name=ferry-vm-1 \
--ram 2048 \
--vcpus 2 \
--disk path=/srv/vm_images/ferry-vm-1.img,size=10 \
--cdrom ~/install/debian-7.1.0-amd64-netinst.iso \
--vnc \
--noautoconsole \
--os-type linux \
--os-variant debianwheezy \
--network bridge:br0 \
--hvm- --name: Name of the virtual client
- --ram: RAM. Memory (in MiB) for the virtual client
- --vcpus: Number of virtual CPUs
- --disk path=,size=:
- --cdrom:
- --vnc:
- --noautoconsole:
- --os-type:
- --os-variant:
- --network:
- --hvm:
