Rough UltimateBootCD PXE HowTo
Posted: Tue Nov 05, 2013 6:24 pm
I've just managed to run the Ultimate Boot CD (UBCD) over PXE (Debian Squeeze as PXE/DHCP server).
The pxelinux.cfg/default configuration block shown in the forum entry on UBCD about PXE booting didn't work for me.
At all.
Here's roughly what I did:
1) I already had a PXE server up and running.
If you don't, then checkout some HowTos on doing that.
2) Download a syslinux tarball:
You'll find syslinux downloads on the kernel.org servers
I've just used "v4.07" (but you might also try the latest one).
3) Copy certain files from syslinux tarball over to your pxe folders:
4) Symlink the com32 files you're using:
For booting the UBCD, I've done that with the following modules/menus:
I've mounted the UBCD's ISO image in /var/tftp/iso-mounted/UltimateBootCD-ubcd527:
6) Add the config in pxelinux.cfg/default:
7) Symlink the "ubcd" folder of the mounted ISO in PXE's root (=/var/tftp):
This is necessary, because the menu ".cfg" files of UBCD refer to "/ubcd/..." all the time.
At all.
tar -xjvf syslinux-4.07.tar.bz2
cp syslinux-4.07/core/pxelinux.0 /var/tftp/
mkdir -p /var/tftp/com32/modules
mkdir -p /var/tftp/com32/menu
cp syslinux-4.07/com32/modules/*.c32 /var/tftp/com32/modules/
cp syslinux-4.07/com32/menu/*.c32 /var/tftp/com32/menu/
ln -s /var/tftp/com32/menu/menu.c32 /var/tftp
ln -s /var/tftp/com32/modules/config.c32 /var/tftp
...5) Mount the UBCD iso-image:cmd.c32, config.c32, linux.c32, menu.c32, vesamenu.c32
sudo mount -o loop ubcd527.iso iso-mounted/UltimateBootCD-ubcd527Code: Select all
LABEL ultimate_boot_cd-527
MENU LABEL Ultimate Boot CD (v5.2.7)
KERNEL menu.c32
APPEND iso-mounted/UltimateBootCD-ubcd527/ubcd/menus/syslinux/main.cfgCode: Select all
ln -s iso-mounted/UltimateBootCD-ubcd527/ubcd/ /var/tftp/ubcd
