Thanks to an answer on "superuser.com", I found a substitute by using "cmp":
$ cmp -l file1.avi file2.avi
- byte offset
- value in first file
- value in second file
It's not as beautiful to read/interact with as vbindiff, but at least it gives you a hint of what's going on.230858726 0 243
230858727 0 266
230858728 0 125
230858729 0 316
230858730 0 117
230858731 0 302
230858732 0 65
If you want to count the differences, you can use "wc" in line-mode:
$ cmp -l file1.avi file2.avi | wc -l
