FFmpeg: FATE lines of code coverage (LCOV)
I'm going to describe the necessary steps to produce an HTML output of code coverage by FFmpeg's FATE tests, just like the one on http://coverage.ffmpeg.org/ :)
It's basically a different version of the article "FATE/TestingCoverage" on FFmpeg wiki.
The OS used is Ubuntu 12.04 (LTS).
Most of these instructions should work for other versions of Ubuntu, as well as Debian too.
Install LCOV package:
$ apt-get install lcov
Compile/build FFmpeg with GCOV support:
Configure your FFmpeg build as usual, but add the following build option:
--toolchain=gcov
In case you've got the fate-suite samples in a non-default location, now would be the right time to add "--samples=path-to-fate-suite/".
Then compile/build FFmpeg:
$ make clean && make
Run FATE tests:
# The -j parameter controls thread number for parallel building
$ make -k -j6 fate
Even though with these parameters tests run in parallel, his can take a while... ;)
Generate LCOV HTML output:
$ make lcov
View HTML page:
Open the file "index.html" in the folder "lcov" in FFmpeg's source tree.
:D
