HowTo: Mount iSCSI on Debian 6 (Squeeze)
Posted: Fri Oct 30, 2015 3:34 am
Install required packages:
Discover existing iSCSI targets on host $HOST_IP:
Should return something like this, for example:
And can be retrieved with:
Connect the iSCSI target:
In my case, I've configured the iSCSI target without any login (for testing). But in order to connect to it, you still need to "login":
Logging in to [iface: default, target: iqn.2015-10.DVA-Hive:Debian_6.lun1, portal: 192.168.1.208,3260]
Login to [iface: default, target: iqn.2015-10.DVA-Hive:Debian_6.lun1, portal: 192.168.1.208,3260]: successful
Show new device:
The iSCSI target will just show up like a raw device (e.g. /dev/sdb).
Partition and format it like a normal device.
You're done!
Based on Falko Timme's HowTo: https://www.howtoforge.com/using-iscsi- ... and-target
$ apt-get install iscsitarget iscsitarget-dkms open-iscsiCode: Select all
$ iscsiadm -m discovery -t st -p $HOST_IPInformation about found/known nodes is stored in: /etc/iscsi/nodes/.192.168.1.208:3260,1 iqn.2015-10.DVA-Hive:Debian_6.lun1
$ iscsiadm -m nodeIn my case, I've configured the iSCSI target without any login (for testing). But in order to connect to it, you still need to "login":
$ iscsiadm -m node --targetname "iqn.2015-10.DVA-Hive:Debian_6.lun1" --loginLogin to [iface: default, target: iqn.2015-10.DVA-Hive:Debian_6.lun1, portal: 192.168.1.208,3260]: successful
Show new device:
$ fdisk -lPartition and format it like a normal device.
You're done!
