DVA-Profession setup notes
Posted: Fri Oct 30, 2015 3:49 am
Here are some notes, missing in the DVA-Profession installation:
1) PHP config file:
/etc/php5/apache2/php.ini
/etc/php5/cli/php.ini
Set memory limit:
memory_limit = 256M
For installation, set the logging to stdout:
display_errors = On
2) Client Samba share:
/etc/fstab
//CLIENT_COMPUTERNAME/DVA-Profession /mnt/video_clients/CLIENT_COMPUTERNAME  cifs  noauto,user,uid=www-data,gid=dva-profession,file_mode=0664,dir_mode=0775,nounix,noserverino,credentials=/etc/samba/credentials/user_ingest
Credentials file:
username=your_username
password=your_password
3) Code changes:
  • SCREEN_SESSION: Replace "mediathek_" with "dva_" to be compatible with new task_trigger startup.
  • Check existence of required executables (ffmpeg, mencoder, etc)
  • Check if required PHP modules are installed (php5-tidy, php5-ffmpeg)
Re: DVA-Profession setup notes
Posted: Tue Jul 11, 2017 3:17 pm
The above notes are mostly outdated.
Newer DVA-Profession installs are done using preconfigured VirtualMachine images.
Nevertheless, here are some more recent notes:
  • After first boot: Change the hostname
  • With existing setups, it's possible to use "create_thin_copy" to spawn new Nexus instances off existing "/opt/dva-profession/workflow" configuration, by using rsync (over SSH) as transfer protocol. This can be done even while the source Nexus is in use.
