function parse_ffprobe_xml
local XML_FILE="$1"
local CODEC_TYPE="$2"
local XPATH_QUERY="/ffprobe/streams/stream[@codec_type='$CODEC_TYPE']"
PROBED_PIXFMT=$($XMLSTARLET sel -t -v "$XPATH_QUERY/@pix_fmt" "$XML_FILE")
PROBED_WIDTH=$($XMLSTARLET sel -t -v "$XPATH_QUERY/@width" "$XML_FILE")
PROBED_FPS=$($XMLSTARLET sel -t -v "$XPATH_QUERY/@r_frame_rate" "$XML_FILE")
PROBED_DURATION=$($XMLSTARLET sel -t -v "$XPATH_QUERY/@duration" "$XML_FILE")
PROBED_DURATION_TS=$($XMLSTARLET sel -t -v "$XPATH_QUERY/@duration_ts" "$XML_FILE")
# Round FPS to 3 digits after the comma:
ROUNDED_FPS=$(echo "scale=3;$PROBED_FPS" | bc -l)
# Round duration to nanoseconds (=9 digits):
ROUNDED_DURATION=$(echo "scale=9;$PROBED_DURATION/1" | bc -l)
# Parse a video METS file, extract certain values from the XML
# and export them as BASH variables.
# Currently parsed:
# METS_ASPECT_RATIO: Aspect ratio of video
# METS_WIDTH: Pixel width of video
# METS_FPS: Frames per second of video
function parse_mets_xml
local METS_FILE="$1"
local XPATH_VIDEO_INFO="/mets/amdSec/techMD/mdWrap/xmlData/VIDEOMD/video_info"
if [[ ! -e "$METS_FILE" || ! -s "$METS_FILE" ]]; then
ERROR_MSG="ERROR: Invalid METS filename given ($METS_FILE)"
return 1
fi
# Select whatever values you like from the METS XML using "xmlstarlet" and XPath expressions:
METS_ASPECT_RATIO=$($XMLSTARLET sel -t -v "$XPATH_VIDEO_INFO/aspect_ratio" "$METS_FILE")
METS_WIDTH=$($XMLSTARLET sel -t -v "$XPATH_VIDEO_INFO/frame/pixels_horizontal" "$METS_FILE")
METS_FPS=$($XMLSTARLET sel -t -v "$XPATH_VIDEO_INFO/frame/frame_rate" "$METS_FILE")
