Installing "odpdown" 0.4.1 on Xubuntu 12.04
HowTo install "odpdown" 0.4.1 on Xubuntu 12.04
1) Download it
Or pull it from the git repository:
https://github.com/thorstenb/odpdown/releases
2) Unpack it
3) Install the following dependencies:
(as root, or using sudo)
$ apt-get install python-setuptools
$ pip install tox
$ pip install mistune
$ pip install lpod-python
4) Run the install script:
Change to the folder where you've unpacked/downloaded odpdown's source code and run this as root:
$ python setup.py install
Running tox tests
For running the "tox" tests, you must install python headers:
$ apt-get install python-dev
Then run the tests:
$ sudo -H tox -v
Should end in:
py27: commands succeeded
flake8: commands succeeded
congratulations :)
