Script to sort JPG by metadata date
Posted: Fri Oct 07, 2016 2:55 pm
This small bash script sorts JPG images recovered using foremost or scalpel.
Their file timestamp is useless, since all recovered files have the current date/time.
Most cameras write the date inside the file as metadata in the form "YYYY:MM:DD".
This script sorts them into a single folder per-month:
#!/bin/bash
ACTION="$1"
FILETYPE="$2"
DIR_OUT="${3:-.}"
YEAR_BEGIN="${4:-1970}"
YEAR_END="${5:-3000}" # Warning: Susceptible to Y3K bug.
case "$ACTION" in
years)
echo "Begin: $YEAR_BEGIN --- End: $YEAR_END"
YEAR="$YEAR_BEGIN"
while [ $YEAR -le $YEAR_END ]; do
MONTH=1
while [ $MONTH -le 12 ]; do
TIMESTAMP=$(printf "%d-%02d\n" "$YEAR" "$MONTH")
TIMESTRING=$(printf "%d:%02d:\n" "$YEAR" "$MONTH")
echo ""
echo "Timestamp: $TIMESTAMP"
TARGET="$DIR_OUT/$TIMESTAMP"
echo "Target: $TARGET"
MONTH=$(($MONTH+ 1))
mkdir "$TARGET"
CMD="grep -l \"$TIMESTRING\" *.$FILETYPE | while read f; do mv \"\$f\" $TARGET; done"
echo "$CMD"
eval "$CMD"
#Remove folder if empty:
rmdir --ignore-fail-on-non-empty "$TARGET"
sleep 1
done
YEAR=$(($YEAR + 1))
done
echo ""
echo "SYNTAX: $0 (ACTION) FILETYPE DIR_OUT YEAR_BEGIN YEAR_END"
echo ""
echo "Example:"
echo " $0 years jpg out 2014 2019"
echo ""
echo ""
esac
