Raspian, SANE and EPSON XP-405 as network scanner
Posted: Mon Nov 07, 2016 3:56 pm
1) Server side (Raspbian 7 Jessie):
USB device for printer/scanner has r/w for group "lp" by default:
/etc/xinetd.d/saned
2) Client side:
In my setup that is Xubuntu 12.04 (64bit).
All you need to do is add server name or IP address of the scanner server to "/etc/sane.d/net.conf".
I would also suggest to enable "connect_timeout" to avoid endless blocking of an application in case the scanner isn't found.
For example, if the server is called "myserver.home", then the net.conf would look like this:
"Simple scan" utility doesn't seem to be able to handle network scanners, so I use "xsane" as scan client application.
That's all.
Have fun!
To be continued.
This is important, since xinetd must be told to run as group "lp" instead of "saned" or "scanner" in order to access the scanner device:crw-rw-r-- 1 root lp 189, 15 Nov 7 12:03 /dev/bus/usb/001/016
/etc/xinetd.d/saned
service sane-port
socket_type = stream
server = /usr/sbin/saned
protocol = tcp
user = saned
group = lp
wait = no
disable = no
2) Client side:
connect_timeout = 60
myserver.home
That's all.
Have fun!
- http://blog.pi3g.com/2013/04/raspberry- ... n-windows/
- https://help.ubuntu.com/community/Scann ... _a_Network
To be continued.
