Makefile for Pandoc: Markdown to HTML
Posted: Sat Sep 30, 2017 2:22 am
This HowTo mainly consists of a Makefile that can be used to convert multiple Markdown (.md) textfiles to HTML using Pandoc (on Linux).
You simply create and edit Markdown textfiles and when you're ready to publish them on the web, tell "GNU make" to compile all of them to HTML:
This is equivalent to "$ make all".
Here's the Makefile for this:
It looks for "*.md" and then calls the "%.html" target rule which calls Pandoc for the Markdown source and then moves the resulting file to the directory defined in "$(OUT)".
Thanks to Niko Heikkilä's example code.
$ makeHere's the Makefile for this:
PD = pandoc
SRC = $(wildcard *.md)
HTML = $(SRC:.md=.html)
OUT = ../
all: clean $(HTML)
%.html: %.md
$(PD) -so $@ $<
echo mv $@ $(OUT)$@
clean:
rm -f *.htmlThanks to Niko Heikkilä's example code.
