HP ProBook 430G6: Install BIOS on Linux
UPDATE:
Unfortunately, the .BIN image extracted with 7zip is not the same that is created when extracting the files "the official way", using Windows. :evil:
See: https://github.com/eriksjolund/install- ... 5/issues/2
Therefore, when trying to update the BIOS, the correct version number is shown to select, but then you get the following error message:
Invalid BIOS image
So the following is (currently) useless:
HP only provides BIOS updates in form of Windows executables, called "sp99776.exe", for example.
In order to flash the BIOS without Windows, these files can be extracted using "7-zip":
$ 7z x sp99776.exe
It'll extract a bunch of files - but the BIOS itself is the file ending with ".bin"
For example:
R71_010901.bin
Copy this file either onto a USB stick, or into the EFI partition, under the following folder:
HP\BIOS\New
Reboot the Notebook, select the System configuration (Press "ESC" at boot).
Then select to update the BIOS.
*fingers crossed*
