JMeter on Ubuntu 6.06
Posted: Mon Nov 27, 2006 7:02 pm
Here's how to get Jakarta JMeter up and running on a fresh Ubuntu 6.06 Server (Dapper Drake) install:
I went for J2SDK, because I'll do some java development on that machine as well, but that shouldn't make any difference regarding this howto.
Option #1 - Using Blackdown Java 1.4.2:
Basically this would be it. Just rename the directory to whatever you like and you're set. It's not beautiful (I'll add info about how to "package" JMeter properly), but it works.
------- AddOns ---------
Add extensions - BeanShell, MailerVisualizer:
- Download JavaMail API here.
- Download JavaBeans Activation Framework here.
- Download BeanShell interpreter:
wget http://www.beanshell.org/bsh-2.0b4.jar
Unpack them and put "mail.jar", "activation.jar" and "bsh*.jar" into JMeter's /lib/ directory.
Add automation support: Ant & JMeter
If you want to automagically execute JMeter testplans, you might want to install "Jakarta Ant", too:
(see my "error posts" below to see why you'll need ant-optional)
Option #2 - Using Sun's Java / binary installer:
In order to install Sun's java cleanly, we'll make a .deb package out of the .bin downloadbable from sun.
(Instructions for installing Sun's Java like that were taken from this forum entry by Adamal)
# install the SDK package:
apt-get install j2sdk1.4
# get some necessary prerequisites:
apt-get install build-essentials libxp6 libxt6 libxext6 libxtst6 libc6
# Download JMeter:
wget http://mirror.deri.at/apache/jakarta/jmeter/binaries/jakarta-jmeter-2.2.tgz
# ....and unpack it:
tar -xzf jakarta-jmeter-2.2.tgz------- AddOns ---------
apt-get install ant ant-optionalOption #2 - Using Sun's Java / binary installer:
# 1) Start by downloading the binary installer from sun
# (e.g. "jdk-1_5_0_09-linux-i586.bin")
# 2) Get some prerequisites:
sudo apt-get install build-essential fakeroot java-package java-common
# FakeRoot is needed for creating the package - Info: http://linux.about.com/cs/linux101/g/fakeroot.htm
# 3) Make a Debian package:
fakeroot make-jpkg jdk-1_5_0_09-linux-i586.bin
# 4) Install the package:
sudo dpkg -i sun-j2sdk1.5_1.5.0+update09_i386.deb
# 5) Set the default java interpreter to be Sun's:
sudo update-alternatives --config java
