VoipStunt on Linux (Ekiga)
This HowTo explains how to setup Ekiga (default softphone client on Ubuntu) for use with an existing VoIPStunt account.
1) First add a new account (Edit > Accounts):
Account Name: Voip Stunt
Registrar: sip.voipstunt.com
User: yourusername
Password: yourpassword
More Options:
Authentication Login: yourusername
Realm/Domain: voipstunt.com
Registration Timeout: 3600
2) According to the VoIPStunt homepage, you can use their STUN server (optional?)
Ekiga Preferences > Network:
Net Traversal Method: STUN
STUN server: stun.voipstunt.com
That's it.
The syntax for placing PC-to-phone calls is:
Edit: I have now tried it without the port number (:5060) and it works.
400: Bad request
Recently, I ran into a strange problem when using Ekiga with VoipStunt:
No matter which call I tried to make, I heard a ringing tone - but the called side didn't even ring. :(
After a few "rings" Ekiga disconnected me and left me with an errormessage:
"Anruf aufgrund eines Fehlers abgebrochen"
(Call cancelled due to an error)
I had to disable the STUN server and use nothing instead. Strange. They (VoipStunt) have probably changed something on their side.
[BACKGROUND]
I used Wireshark to take a look at the SIP packets (WireShark is grrrrreat - just a few clicks and it digs out SIP calls in a stack of packets - lovely!) - and I saw a strange sequence:
Ekiga: INVITE > Voipstunt
Ekiga: CANCEL > Voipstunt
Voipstunt: 400 Bad request > Ekiga
Why is there a cancel after an invite coming from my side? However. Disabling STUN fixed the problem, although I must admit that I didn't really understand the reason.
