There's also some info in the Ubuntu wiki about FreeNX.
The windows client should have come from NoMachine, but the never client version (2.1.0) doesn't work with FreeNX 1.4.x anymore - so luckily I ran across the older client .exe: http://www.arte.unipi.it/Public/Win32/n ... .0-138.exe
This client was able to connect to my server, but I wanted to "enable printer and file sharing" (service tab) and ran into several errors:
1) smbfs wasn't installed:
- install the "smbfs" package.smbmnt: command not found
2)
According to these instructions, execute the following commands:Info: Share: '//W2KSQLSRV/d' failed to mount: smbmnt must be installed suid root for direct user mounts (1001,1001)
smbmnt failed: 1
$ sudo chmod u+s `which smbmnt`
$ sudo chmod u+s `which smbumount`
