The system does not boot and is stuck at some BIOS tests.
There is a setting in the Bios where you can set the HDD priority if you set the bootup sequence to HDD being the 1st Boot sequence. After attaching new USB devices, enter BIOS and check if the USB Stick still is the first device in the HDD list.
