When you've created a shortcut on the desktop using "Connect to server" on Ubuntu 6.06, it's unfortunately impossible to edit it later on.
Currently you can only delete it and create a new one in order to make a minor change.
Even something simple as renaming an entry is impossible. (or maybe I'm just too stupid to figure it out)
You can manually edit those entries, using the gconf-editor and changing values of entries below this key:
/desktop/gnome/connected_servers/
Ubuntu: Editing "connect to server" entry
