Recovery of OpenDocument files
Unfortunately, it sometimes may happen that your .odt file is broken. In my case it was because that file was formerly a .doc file - and the conversion seems to have messed up the styles.xml within the newly saved .odt.
I ended up with blue pages and strange vertical lines across them - For some reason those blue pages were actually tables of some sort. strange.
But the OpenDocument file format came to the rescue!
Method 1)
Simply open the file with your favorite .zip archive manager (e.g. right-click on it an choose "archive manager" in Gnome) and then delete the "styles.xml".
Re-open it with OpenOffice and your text should be there.
Method 2)
In case more files than just your styles.xml puked on themselves, you can transplant your "content.xml":
- Create a new, empty OpenOffice Write document and save it.
- Unpack "content.xml" from your broken file.
- Put this content.xml into your empty, new file.
That's it. Your text should be back again.
