Status of "dd" process
When using the powerful tool "dd", it would sometimes be nice to know how much data is has already copied. By default it's not outputting anything until it's done.
Sending a "USR1" signal to the dd process, will make it output its status:
kill -USR1 <process_id_of_dd>
In case you'd like to have status information printed out every x seconds, just use "watch" in combination:
watch -n <seconds> kill -USR1 <process_id_of_dd>
