MEncoder: Extract audio from video
I wanted to extract only the audio track from a video into an audiofile.
Since the video was split into 1-minute segments, I had to use mplayer or mencoder - as FFmpeg did not reliably glue all audio samples together in my tests.
Using mplayer takes extremely long, as it seems it tries to export it in realtime while playing it back (even with -vo null).
So, thanks to a post by the user "wasp" in the Knowledge.Drun.NET forums, here's how to extract the raw audio stream (PCM encoded) of segmented videos, using mencoder:
mencoder -of rawaudio -oac pcm -ovc copy -o OUTPUT.wav INPUT_VIDEO/*.avi
