For some (yet unknown) reason, I'm recently having issues with my ISC DHCP server setup. It usually runs incredibly reliable, but now, some clients just won't get a reply from the DHCP server
There's a nice list of ISC DHCP troubleshooting tips in an article on "prefetch.net".
The first thing to do is check the logs. By default, the ISC-DHCP server writes to /var/log/messages and/or /var/log/syslog.
Syslog seems to contain more information in some cases, and it looks like it also contains the things that go to "messages". Let's take a look:
$ tail /var/log/syslogSo I tried "tcpdump" to see if the DHCP-requests are coming in:
$ sudo tcpdump -n -i eth0 port bootps or port bootpc...but the DHCP server didn't feel like it should respondtcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
15:43:50.935162 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:50:56:97:xx:xx, length 300
15:43:53.891102 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:50:56:97:xx:xx, length 300
15:43:58.474148 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:50:56:97:xx:xx, length 300
15:44:01.797033 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:50:56:97:xx:xx, length 300
15:44:07.946109 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:50:56:97:xx:xx, length 300
Checking /var/log/syslog again, I now had the following lines in there:
[SOLUTION]Jul 2 15:57:41 hostname dhcpd: DHCPDISCOVER from 00:50:56:97:xx:xx via eth0: peer holds all free leases
Jul 2 15:57:45 hostname dhcpd: DHCPDISCOVER from 00:50:56:97:xx:xx via eth0: peer holds all free leases
Jul 2 15:57:50 hostname dhcpd: DHCPDISCOVER from 00:50:56:97:xx:xx via eth0: peer holds all free leases
My setup is configured with 2 failover-DHCPs, where one is currently offline.
I tried to set the state of the running dhcpd to "partner-down", since the secondary dhcpd is down for maintenance for a longer time.
Thanks to the DHCPd failover article on Frederik's blog, I got an idea of how to configure the "omapi" for using "omshell".
The state of the dhcpd must be changed to "partner-down", but I'm still reading up on how to do this.
