Trying to install the XML Tools plugin in Notepad++ (v7) on Win7 using the "Plugin Manager".
XML Tools shows up in the list of available plugins, but when you click "Install" the progress bars stay empty until a timeout - and then it says it failed to install.
Try starting Notepad++ as Administrator and then try again
Notepad++: XML Tools plugin fails to install
