Grub2, chroot on mdadm RAID 1
Trying to install GRUB on 2TB harddisks, GPT with software RAID 1...
grub-install in chroot of mounted md127 throws error:
grub-install /dev/sda
/usr/sbin/grub-probe: error: no such disk.
Auto-detection of a filesystem of /dev/md127 failed.
I had to install "mdadm" on the target (chroot) system.
Next error:
$ grub-probe -d /dev/md127
Returned:
Changed to metadata version of the mdadm RAID to 0.90.
Had to add "--recheck". Then it worked:
$ grub-install --recheck /dev/sda"
Uncomfortable.
Re: Grub2, chroot on mdadm RAID 1
Workaround for initial boot (OS root on first partition of "md/0") - with mdadm metadata version 1.2 (!)
ls
ls (md/0,msdos1)/
set root=(md/0,msdos1)
ls /
set prefix=(md/0,msdos1)/boot/grub
insmod mdraid
insmod linux
normal
The above notes seem to be incomplete. At least, the didn't work like that the 2nd time I ran into the same problem.
Here are new notes:
  • target system =Debian 6 (Squeeze)
  • Partition the disks for target system:
    20GB (filetype "fd" = Linux raid autodetect)
    Leave rest unpartitioned. Starting at sector 2048 (1TB disks)
  • Create the mdadm RAID1 for the target system:
    mdadm --create /dev/md0 --level=1 --raid-devices=2 /dev/sda1 /dev/sdb1
    20 GB (ext4) (5% reserved for root)
  • mount target system (Debian Squeeze) on Live distro (Ubuntu 14.04)
  • mount sys,proc,dev on target system:
    mount -o bind /sys <target>/sys
    mount -o bind /proc <target>/proc
    mount -o bind /dev <target>/dev
  • chroot to the target system
On the chrooted target system:
  • grub-mkdevicemap -n
  • update-grub
  • grub-install /dev/sda
    grub-install /dev/sdb
