Debian 9 Stretch: Access denied for user 'root'@'localhost'
Installed mysql-server (actually "MariaDB" now in Debian Stretch ;)) as usual.
I was never asked for a mysql root password... :?
Seems that the following command must be called:
$ sudo mysql_secure_installation
Then enter a mariadb root user password, answer (most of) the questions with "Y".
Assuming I could login now, I got:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
:shock:
For "classic" authentication behavior, you must switch the (new) default 'unix_socket' to 'mysql_native_password'.
See details (and more detailed solution at stackoverflow and step-by-step instructions at Childsplay's blog).
Here's the short version:
$ sudo mariadb -u root
Then enter the following SQL commands:
USE mysql;
UPDATE user SET plugin='mysql_native_password' WHERE User='root';
FLUSH PRIVILEGES;
EXIT
Should work as previously expected now, using the password you've entered in "mysql_secure_installation".
:D
