FFmpeg: Filtering and streamcopy cannot be used together.
peter_b
Chatterbox
Post by peter_b »
I was trying to generate framemd5 for video and audio in one step:
$ ffmpeg -i bars.mov -map 0 -c copy -flags +ildct+ilme -field_order bb rewrap.mkv \
-an -f framemd5 bars.video.framemd5 \
-vn -c:a pcm_s24le -filter_complex "asetnsamples=n=48000" -f framemd5 bars.audio.framemd5
But the part for audio (that included "-filter_complex") triggers this error message:
Streamcopy requested for output stream 0:0, which is fed from a complex filtergraph. Filtering and streamcopy cannot be used together.
This error message suggests that FFmpeg thinks "filter_complex" is to be applied to video too (stream 0:0), but we only want to apply it to audio.
How to tell FFmpeg that we don't touch video, but only want to group the audio samples for frameMD5 hashing them?
It seems that "-filter_complex" for audio can be replaced by "-af" (audio filter) to make this work:
-vn -c:a pcm_s24le -af "asetnsamples=n=48000" -f framemd5 bars.audio.framemd5
Works! :D
