DaVinci Resolve Lite 16.0 on Xubuntu Xenial (v16.04.3). Installed using "MakeResolveDeb" (Thanks Daniel!).
Resolve crashes right after trying to run it after install.
The logfile "~/.local/share/DaVinciResolve/logs/ResolveDebug.txt" says:
And after that:==========[CRASH DUMP]==========
Please send this to support:
#TIME Fri Aug 9 00:45:08 2019 - Uptime 00:00:20 (hh:mm:ss)
#PROGRAM_NAME DaVinci Resolve v16.0.0.060 (Linux/Clang)
/opt/resolve/bin/resolve() [0x509f8b9]
/opt/resolve/bin/resolve() [0x509f0aa]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7fcb86af6390]
Signal Number = 11
I wouldn't know where to start.[0x7fcb7ab9eb00] | SyManager.Signals | INFO | 2019-08-09 00:45:08,857 | Main view page is changed to 2
[0x7fcb7ab9eb00] | UI | WARN | 2019-08-09 00:45:08,954 | Layout is disabled.
[0x7fcb4e930700] | CrashReport | ERROR | 2019-08-09 00:45:09,462 | Compress() : Failed to add file to archive.
ActCCMessage Already in Table: Code= c005, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c006, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c007, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= 2282, Mode= 0, Level= 0, CmdKey= 8, Option= 0
PnlMsgActionStringAdapter Already in Table: Code= 615e, Mode= 0, Level= 0, CmdKey= -1, Option= 0
log4cxx: No appender could be found for logger (Main).
log4cxx: Please initialize the log4cxx system properly.
Maybe libpthread?
