function map_through () {
echo "IPT PortMapping: ";
LAST_SERVER=""; #stores the last found server IP.
LAST_PROTO=""; #stores the last found protocol (TCP, UDP,...)
for map in $1
do
PROTO=`echo $map | awk -F":" '{print $1}'`
PORT_IN=`echo $map | awk -F":" '{print $2}'`
IP_SERVER=`echo $map | awk -F":" '{print $3}'`
PORT_OUT=`echo $map | awk -F":" '{print $4}'`
# Remember/Use last valid server ip:
if [ -z "$IP_SERVER" ]; then IP_SERVER=$LAST_SERVER; else LAST_SERVER=$IP_SERVER; fi
# assume PORT_IN==PORT_OUT, if no PORT_OUT given:
if [ -z "$PORT_OUT" ]; then PORT_OUT=$PORT_IN; fi
# Remember/Use last valid protocol:
if [ -z "$PROTO" ]; then PROTO=$LAST_PROTO; else LAST_PROTO=$PROTO; fi
case "$PROTO" in
U) PROTOCOLS="UDP"; ;;
T) PROTOCOLS="TCP"; ;;
UT) PROTOCOLS="UDP TCP"; ;;
*) PROTOCOLS="TCP"; ;; # Default Protocol
esac
if [[ -n "$PORT_IN" && -n "$PORT_OUT" ]] && [ -n "$IP_SERVER" ]
then
for PROTO in $PROTOCOLS; do
echo " - ($PROTO) From $PORT_IN to $IP_SERVER:$PORT_OUT"
# ${IPTABLES} -A PREROUTING -i ${OUT_DEV} -t nat -p $PROTO --dport $PORT_IN -j DNAT --to ${IP_SERVER}:${PORT_OUT}
# ${IPTABLES} -A FORWARD -p $PROTO -d ${IP_SERVER} --dport $PORT_OUT -i ${OUT_DEV} -o ${INT_DEV} -j ACCEPT
done
fi
done
TESTMAP="U::192.168.1.10: :9999::1234 UT:20000:: ";
map_through "$TESTMAP"
