Oracle: Running under SuSE 10
While trying to install Oracle 10g, I received the following message:
Checking operating system version: must be redhat-3, SuSE-9, redhat-4, UnitedLinux-1.0, asianux-1 or asianux-2
Failed <<<<
run the installer with this parameter:
./runInstaller -IGNORESYSPREREQS
[My-2-cents]
Every time I have to touch oracle, it gives me another reason why I do NOT like it.
Where is "rcoracle" (/etc/init.d/oracle)?
Oracle's installation does NOT seem to come with proper startup scripts useful in the SysV init process.
Check the SuSE ftp for RPMs including startup files for oracle.
I didn't want to blindly execute this RPM, so I unpacked it to use only the startup scripts I wanted, using this:
rpm2cpio foo.rpm | cpio -idmv --no-absolute-filenames
I couldn't find a ready file for /etc/sysconfig/oracle, so I created my own, based on the code in /etc/init.d/oracle:
#!/bin/bash
SET_ORACLE_KERNEL_PARAMETERS="yes";
START_ORACLE_DB_OCFS="no";
START_ORACLE_DB_OCM="no";
START_ORACLE_DB_GSD="no";
START_ORACLE_DB_LISTENER="yes";
START_ORACLE_DB="yes";
START_ORACLE_DB_APACHE="no";
START_ORACLE_DB_CMANAGER="no";
START_ORACLE_DB_AGENT="no";
START_ORACLE_DB_IFS="no";
START_ORACLE_DB_OID="no";
wrong, static path in "dbstart"
When starting oracle using "$ORACLE_HOME/bin/dbstart" that's coming with it, I received the following error:
Failed to auto-start Oracle Net Listene using /ade/vikrkuma_new/oracle/bin/tnslsnr
Obiously, the creator of "dbstart" whose username seems to be 'vikrkuma' has left us with this line here:
# Set this to bring up Oracle Net Listener
ORACLE_HOME_LISTNER=/ade/vikrkuma_new/oracle
by setting this variable to $ORACLE_HOME, everything's back in place where it belongs.
PHP, wwwrun and Oracle 10g
By default, apache is running as user 'wwwrun', Oracle 10g has its default accessrights configured so that ONLY the oracle-user or members of the dba-group (specified during installation) can even list subdirs of $ORACLE_HOME.
Thus, you get the nice error:
oci_open_server: Error while trying to retrieve text for error ORA-12154"
although your ORACLE_HOME and ORACLE_SID is set properly.
I always thought that "dba" was short for "Database Administrat[or|ion]", but apparently it means "DB-access".
so: add 'wwwrun' to your dba-group, restart apache (YES! that's important - and it took me almost 1 hour to find that out) and you're set.
