Festival TTS failed to compile
Posted: Tue Feb 03, 2004 7:08 am
When trying to compile 'festival' (http://www.cstr.ed.ac.uk/projects/festival/), I've ran across 2 compile errors because of 'termcap' being used.
Although the docs for festival say, that the 'editline' is optional (in 'speech_tools') because it might not compile on some platforms, I've decided to go the hard way - AND it did complain about missing the 'termcap' library.
Since termcap has been replaced by ncurses long ago (as I've read), I've simply symlinked '/usr/lib/libtermcap.so' to '/usr/lib/libncurses.so' which made it possible to compile the speech_tools.
Right afterwards, festival itself failed to compile and exited with several "undefined references" in 'festival_main.cc'. After it exits, simply change to the 'festival/src/main/' directory and compile the file manually, BUT add '-lncurses':
gcc -O3 -Wall -o festival festival_main.o \
-L../../src/lib -lFestival \
-L../../../speech_tools/lib \
-lestools \
-lestbase \
-leststring \
-ldl \
-lm \
-lstdc++ \
-lncurses
...now switch back to festival's root directory and run 'make' again.
-lestools \
-lestbase \
-leststring \
-ldl \
-lm \
-lstdc++ \
-lncurses
