Deterministic Network Enhancer
Posted: Sat May 22, 2004 4:02 pm
1) Windows tries to install something called "Deterministic Network Enhancer Miniport"
2) After accepting the non-Micro$oft certified driver, the network connection says it's up (according to the 'connected'-icons in the systray), but disappeared from the 'ipconfig' listing completely :shock:
3) Trying to deinstall this obscure driver from the hardware-management says something like "unable to do this, because the system might need it for startup"
go to the network connection's properties tab and you should see this alien-driver in the assigned list. Uninstall it from there and it will disappear from the controlpanel, too.
Can you elaborate
Posted: Fri Sep 02, 2005 4:39 am
by guest
Can you elaborate? This thing is not letting my Cisco PNV work correctly.
Thanks,
Brooks
need more info
Posted: Fri Sep 02, 2005 1:50 pm
In order to help you, I'd need a little bit more info about what you need - or what exactly your problem is.
(and to be honest: I don't know what a "PNV" is...)
