Wrong uid, gid after copying.
Posted: Sun Jul 25, 2004 3:07 pm
Files/Directories having wrong userids and/or groupids after copying data on a disk mounted in a foreign system (e.g. Knoppix)
[EXPLANATION]
The problem is, that when copying files using 'cp', the system resolves names to IDs, but uses the IDs of the currently booted system (which was in our case Knoppix).
...avoid using 'cp' when copying files for a system which is NOT the one booted.
OR make sure that the IDs of the two systems match.
[EXPLANATION]
