Linux: SBLive & MIDI
Posted: Sat Jun 14, 2008 8:00 pm
Midi plays back, but there's no sound.
You must load soundfonts into the SBLive. You can get them from the SBLive CD or for starters, you can use the default soundfont:
8mbgmsfx.sf2 (available on ALSA homepage)
On Ubuntu, do the following:
- Install "awesfx" package:
- Load the soundfont:
Thanks to the SBLive MIDI HowTo by El-Biero
apt-get install awesfxCode: Select all
sfxload -b0 /path/to/soundfont/8mbgmsfx.sf2
