[Linux] Check disk integrity
gilthanaz
Contact:
Post by gilthanaz »
Use badblocks to do a full disk check (each sector):
Non-destructive method:
# badblocks -vs /dev/hda
Checking for bad blocks in read-only mode
Arguments:
  • -v: verbose
  • -s: show progress in rough percentage
DESTRUCTIVE METHOD:
# badblocks -ws /dev/hda
Tests each block by first writing in, than reading from it. Do not use this on an existing filesystem, it WILL DESTROY all data!
Arguments:
  • -w: write-mode test
If you want also a write test on an existing filesystem without destruction of data, use the -n option. Its way slower that way, but keeps the data intact.
Reason: Added infos about used badblocks arguments.
store badblocks in textfile
Other useful options for badblocks are the ability to store/read a list of bad blocks in/from a file.
1) Store list of bad blocks in file:
Run badblocks and store the list of broken blocks in a file:
badblocks -o bad_list.txt -vs /dev/hda
2) Speed up scanning for bad blocks:
If you run badblocks again, you might want to skip testing blocks you already know to be broken:
badblocks -i bad_list.txt -vs /dev/hda
3) Format partition and mark bad blocks:
If you have bad blocks, you might want to tell the format tool about them.
Example for ext3:
mkfs.ext3 -l bad_list.txt /dev/hda
Example for fat32 (=vfat):
mkfs.vfat -l bad_list.txt /dev/hda
4) Compare different runs:
If you run badblocks on the same device in the future, you can compare the list with previous runs to see if the number of bad blocks is increasing (which usually means that your harddisk is about to die)
