In order to use USB devices within the virtual machines, you must make the deprecated "/proc/bus/usb" available. Thanks to the instructions found in "Howto: Install VirtualBox in Ubuntu Hardy Heron with USB Support in 5 easy Steps!", it was no problem.
Simply do the following:
1) Open /etc/init.d/mountdevsubfs.sh in your favorite text editor - as root (!).
2) Look for this code:
# Magic to make /proc/bus/usb work
#mkdir -p /dev/bus/usb/.usbfs
#domount usbfs "" /dev/bus/usb/.usbfs -obusmode=0700,devmode=0600,listmode=0644
#ln -s .usbfs/devices /dev/bus/usb/devices
#mount --rbind /dev/bus/usb /proc/bus/usb
If all went well, the output of "ls /proc/bus/usb/" will match the output of "ls /dev/bus/usb/" - making the devices available to Qemulator's device list.sudo /etc/init.d/mountdevsubfs.sh start
4) In Qemulator, enable USB support for your virtual machine:
- Select "My Machines"
- "show settings" and select "Hardware". Check "enable usb" in the lower right corner.
- Start the virtual machine
- in Qemulator, open the "Running jobs" tab and right-click on your virtual machine entry and click "open control monitor"
5) In the control monitor, you have a tab called "USB" where you should now see all attached USB devices in the upper half.
Just select a device you want to use and click "add". It should now show up in the virtual system as if it had just been plugged in.
Enjoy!
open the "Running jobs" tab and right-click on the
