smbfs: mount_data version 1919251317 is not supported
Posted: Fri Jun 04, 2010 1:39 pm
I wanted to mount a Samba share using an /etc/fstab entry. But after doing a "sudo mount ..." I got the following errormessage:
Thanks to a
blog entry by Sébastian Wains, it was simply a matter of:
to fix it.
Long story short: If you're getting this error, you simply don't have the "smbfs" package installed.
(The system was running Kubuntu Hardy 8.04.1)smbfs: mount_data version 1919251317 is not supported
Thanks to a
sudo apt-get install smbfsLong story short: If you're getting this error, you simply don't have the "smbfs" package installed.
