Krita v1.6 can't handle resolution and always uses 72 dpi
Posted: Thu Jul 22, 2010 9:52 am
PROBLEM
I've been using Krita for a long time now to convert between colorspaces (RGB/CMYK) for printing. Unfortunately, it seems that Krita in version 1.6 is not able to store a DPI resolution value for the image, so it always defaults to 72 dpi.
WORKAROUND
So, in order to just add the resolution information to the image, I've just used ImageMagick, like this:
convert input-cmyk.tiff -density 300 -compress zip output-cmyk.tiff
The important option is "density". I've also added the compression explicitly to avoid problems with the default settings of ImageMagick.
