svn: Malformed network data
Posted: Mon Apr 11, 2011 1:31 pm
Recently, I tried to access a local in-house SVN on our server, and received the following error message - regardless of what action I tried (checkout, update, ...):
The actual repository files were stored on an external harddisk (USB) - and it had been de-attached, so svnserve pointed to a non-existing repository folder.
So, if you run into that error on your own server, check if that the repository data is locally accessible on that machine
I've tried restarting the inetd on the SVN server, but that didn't help.svn: Malformed network data
