svn: Get highest revision number of directory tree
I wanted to update my production version to a certain revision, which has been used as internal release-candidate version within the development team.
Since it was only internally used, it hasn't been svn-tagged, so I wanted to find out which revision number that release-candidate had.
Using "svn info" only works for individual files - and they came from mixed revisions, so it wasn't guaranteed to be the most recent revision used.
Calling "svnversion" (comes with SVN by default) in the affected directory, returned exactly the result I was looking for, and shows which revision range exists in the folder.
An example result is as follows:
195:202M
This means, that in my release-candidate folder, I had files from revision 195 up to 202.
